seicento speedometer problems
danielscott
Hi all can any one help me with the speedo it is sticking at 40mph when you 1st start up
many thanks :confused:
Dan
If cable operated, it'd be worthwhile trying a new cable. If digital (MPI cars) suspect the wiring to the speed sensor (on the differential) or the speed sensor itself.
Failing that, the unit is probably fubar, but if cable you might check that no grease has entered the unit. Either should be dirt cheap from a scrappy.
either way youll have to remove your instrument pod. There is a guide on how to remove this in the Seicento guides
