Hi, I had trouble with my Scudo van earlier in the year when we had some heavy rain, and have now had the same thing happen today.
Basically, if its raining very hard the van just wont start - it turns over and occasionally fires up, but as soon as you give it any revs it cuts out. Eventually, after leaving it for a while, I can get it to go, but need to gently rev it for a minute of so before it will pull away without cutting out.
Also, a similar thing happens if I go through a large puddle - it splutters about for a while before the engine just cuts out, leading to the same problem as before.
Is there anything in particular that could be causing this and, if so, is there any way to stop it?
