Hi all, I wonder if I can call on the vast experience of you all. I have just fitted my new exhaust and have now been able to move onto the next problem. When I load the engine at low revs in particular, she splutters and cuts out till I back off and change down a gear to increase the revs. Also from idle, when I push down on the throttle she is slightly hesitant.
My thoughts so far are:
1) The usual blocked jet in the carb problem!
2) Vacuum advance?
3) There is still a slight leak from the exhaust pipe but not a lot.
4) Air filter looks quite dirty, maybe she is running too lean?
5) Old points might need replacing
I will start to go through this list first thing in the morning, but what do people think is the most likely cause?
Thanks for any help, allways much appreciated!!
Si
2) Vacuum advance?
Si
