I've got a few parts for sale. I'm listing here since the Strada is a fairly rare motor and this section is quiet anyway.
Original passenger wing - painted but as new
drivers wing - pattern part
Sills covers and one sill for 3 door
Tailgate - needs a bit of work to repair some rust will be availble once I've repaired.
Rear wheel arch repair panels both sides
Passenger side door skin (pattern but very good)
Steering rack with track rod arms
2 sets of front calipers + 1 extra
track control arms - boxed new - rare
Body kit - would need some work with a bit of filler and spraying before fitting in my opinion.
Body kit - 2 sets of both front arch sections and a rear drivers side section.
oil pump
rear lights plus at least 1 spare lense
2 sets of indicator stalks (not broken) - 1 SET SOLD
Drive shafts both sides + at least one extra
Mk2 grill (brand new)
Mk3 grill
Fuel pump
130TC sump
New 130TC Exhaust (Ansa)
New Thermostat
New Water Pump
New Cambelt
New brake balancer
New 130TC Head Gasket set
Steering column and ignition switch + key
Loom
A couple headlights (RHD) one with rust one good.
Brand new passenger side mirror
Fuel Filler Pipe
Rear leaf Spring
Set of seat belts
Complete Gear change mechanism and gearstick
Engine mount
Complete airbox including mesh insert
New front indicators
Abarth horn press
Parcel shelf unfortunately with speakers
Loads of trim and other bits
Mk3 door card with handle etc (passenger side)
Mk3 rear boot panel
Trim either side from the boot
A, B & C interior pillar trims
rear quarter trims both sides
door trim - around carpet
interior lights
headrest
couple of washer tanks
door winders
dash ash tray complete
sunvisors
door bins
passenger side mirror and glass (used)
bit of glass for rear quarter (drivers side)
Bodykit clips doors - not brokwn.
front bumper - pretty poor condition
new front brake hoses - normal rubber
new front brake hoses - braided goodrich
Brake pads
1 brake disc used but good
Please be aware when I indicate a side this is for a RHD car so reverse for LHD.
Thanks Trevor
oil pump
Mk3 grill
Fuel pump
130TC sump
New Thermostat
New Water Pump
New Cambelt
New brake balancer
Loom
Fuel Filler Pipe
Rear leaf Spring
Set of seat belts
Engine mount
Abarth horn press
Mk3 rear boot panel
interior lights
headrest
door winders
sunvisors
door bins
Brake pads
Thanks Trevor
