Technical Centre air vents not blowing
punto2009
My sister just bought a mk1 Punto and the centre air vents dont seem to blow any air on any setting. The centre and top centre vents.
What could have caused this?
I've found it sometimes pays to ask the obvious. I don't suppose you park under any deciduous trees do you? I occasionally get the odd leaf blown through the system, you could have a forest's worth in there.
Well the cars new so im not sure where it was before. How can i check for blockages?
I've not actually taken apart the blower matrices, but have you tried closing all other vents and setting the fan to full-blast? Might dislodge whatever is in there. Alternatively, take the vent fronts off an shove a slim vacuum cleaner pipe down there. It should be long enough to reach any blockage since the centre's feed is not that long.
