Redpunto2004
- Joined
- Nov 11, 2004
- Messages
- 7
- Points
- 2
Ive got a 1997 punto 55 s and Ive got to change the nearside rear radius arm. Ive got it downto the last bolt which goes through the end of the radius arm and into a mounting bracket either side. The bolts about 8 inches long and runs through a bearing in the radius arm. Its only threaded on the bit that sticks out the mounting for the nut to go on. Ive got the nut off, and now cant get the bolt out, Its seized to the bearings inside so turning it just turns the bearings. Ive tried beating the hell out of it with a lump hammer, and it didnt move at all, and Ive tried sawing it off between the mounts and the arm but the gap is way too thin to get a saw blade in. Anyone had this problem or has a solution, it would be greatly appreciated if someone could help with any ideas.
