- Joined
- Oct 9, 2006
- Messages
- 774
- Points
- 227
Hi
changed leads, plugs, set 0.9mm gap at all plugs, resetted ECU (done around 30miles after), and it have serious cutouts when idling at around 2-3k rpm-while rapidly accelerating, no problem at all, only when staying at those revs, engine seriously cutout, car almost want to stop.. any ideas???? i had this before, but not so much, only small flatouts..
also changed radiator, clutch, thermostat etc... but it have nothing to do with..???
help urgently needed, on friday long trip... thanks.. also check this please:
"fan start at around 95degrees, and after few seconds stops-engine is not overheating, but I think its too short time
and it doesnt depends on revs, idle or 4krpm, still the same
checked everything, leads, no problem at all.. looks like that fan switch is crap, but that old one was working almost same... maybe thermo gauge is fault????
btw. new radiator, coolant, thermostat, fan switch, properly maintained.."
