Hello there,
Wondering if I could run my problem by some knowledgeable people here before it goes to the garage.
I've got a 1999 S reg Punto (mk 1)
A few weeks ago the clutch got quite stiff around the bite point, and also when in neutral I could hear a bit of crunching when pressing down the clutch.
The problem magically vanished a few days later (over the weekend), so I forgot about it.
A day or two ago the symptoms returned.
Also today I have had problems putting the car into 1st gear. Wouldn't go in at all if moved down from 3rd, I needed to stop the engine, move into 1st, and start the engine again. I did manage to move it into 1st a few times after that, but was difficult. The other gears didnt seem to be such a problem though.
Also heard crunching when trying to put into reverse, although worked ok.
I didnt want to drive after that, so left the car at work.
I think something is up with the gearbox/clutch
Its booked for a service at an AA service centre this Wednesday, so they can probably have a look then.
What do you think is the problem and how much money am I looking at?
(NB I've got a mate at work who used to be a mechanic, so he might be able to take a look tomorrrow if hes in)
Many thanks,
James
Many thanks,
James
