Technical Transmission/clutch problem
huntercheif
My Palio Weekend has been running great until recently it just started to have a problem when letting the clutch out into gear. There is a chunky feeling as if the gears are not quite catching properly along with a low noise under the car. It drives fine once in gear.
Where can I check my clutch fluid and manual transmission fluid levels?
What kind of engine, what year?
It's a 1996 (silver!) 1.4.
When I put the clutch in and give it gas it goes smoothly, but as I let the clutch almost out all the way out, right at the end there is a rattling kind of action and the the car is jerking slightly.
A 1996 Palio Weekend 1,4...??
Oh, you're right, it's a 1998, sorry, with 142.000 km. I can't find any reservoir to fill the clutch fluid, I wonder if it uses the brake fluid? That level is fine. Do you know how much it would cost to replace the clutch assembly?
