Hi Guys,
Just wondered if anyone has any advice on this problem,
When i change into upto OR down to 2nd gear my stilo crunches BUT if i pull the stick back slowly and carefully it goes in fine but that then means i cant pull out of a junction with any speed as the change to 2nd will be nasty.
Is this a clutch problem or gear box prob? The car stalls when tryin to pull off in 5th so there is no clutch slip. My local nationwide autocentre quoted £490 for clutch and slave cylinder/thrust bearing. Is that high or standard?
I obviously dont wanna be paying £490 for a clutch if its the box.
(Does the 1.2 - 6 speed box fit the 1.6??) hmmm?
