I've just bought a Marea Weekend 2.0 HLX, which has a few minor problems that need sorting before I can get on to the fun stuff like the air box mod. Any help on these issues would be much appreciated. Thanks.
The ABS light comes on (and stays on) at speeds above 70mph. I've heard that the rotor part of the ABS sensor is part of the wheel bearing assembly on these cars, if this is true is it possible that the wrong part has been fitted? I guess it could also be due to a faulty sensor, but its odd that it only happens at speed.
The tachometer reads zero at idle and I suspect that its under reading at other engine speeds - I get about 3200rpm at 80mph in 5th gear. What could cause this problem?
How long should it take for the engine to reach normal operating temperature, and what is that temperature? Mine needs 10-15 minutes to reach the 2/5 mark on the gauge which is longer than I'd expect.
