Hi All
The other problem I'm experiencing with my X is bleeding the brakes.
The cylinder was resleeved and made all neat and shiny. When I tried to bleed the rear brakes there was no brake fluid going to the back (reservoirs are filled up) and the front right brake. The left one squirts out brake fluid but as soon the pedal is depressed and the nipple closed off the cylinder "rod" seems to be stuck.
So, it is only the left front brake where I have fluid coming through and nowhere else. If I take the bleed niple off the others then I can feel some movement but not enough to have the fluid squirting out.
Any help will e appreciated.
Aldino
Aldino
