I have a 1994 Punto 75 with a problem with locked rear wheels.
At first I thought it was due to the brakes, but now I am not so sure. Investigating the passenger's side rear drum (using a jack and the wheel taken off) I noticed that it has very slight rotation of about 1 or 2 degrees, but seems mechanically blocked somehow. I ruled out a braking problem because when the parking or foot brakes are applied there is no rotation at all (I tried them both independently). However, this is only my assumption until now, correct me if I am wrong.
Is there some type of locking mechanism that could be stuck, independent of the shoes?
I've tried tapping the drum with a hammer, forcibly driving forward (with the result of simply dragging the locked rear wheels).
Due to the current parking situation it is difficult to get to the driver's side rear wheel, so I am not completely certain that this wheel has the same problem, but I assumed it would be much easier to move the car if only one wheel were locked, so I assume both are locked.
Any suggestions would be greatly appreciated.
Thanks,
Donn
Thanks,
Donn
