Technical Seicento coolant sender connection at dashboard
jimp
Edinburgh
Can anybody tell me where the line from the coolant temperature switch goes into the dashboard clocks pod on my Sporting SPI?
Under the bonnet its a green/white line but I don't see that colour on the edge connectors at the rear of the clocks. I CAN bell it out,but I just wondered if anybody knew straight off which line/colour it is at the connectors...
It's for the "oh sh*t" light.
The radiator fan won't go up there, only to the fuse box I would think. I was expecting to see a green/white going in on an edge connector but the only thing vaguely near that is a pale green.
sorry- I've only just realised you had responded to this thread!
I was trying to utilise the existing wiring from the Temp switch and tap it for the gauge I was fitting instead- but I just ran a new line after all...
