D dekel New member Joined May 5, 2008 Messages 1 Points 1 May 5, 2008 #1 I have a question, is it possible to swap the engine of a Marea 1.6l 16v to a tipo ??? thx
maddogmorg BRUM!! Parked in the garage Joined Feb 6, 2006 Messages 4,060 Points 634 Location Weston-sloping-Mare May 5, 2008 #2 should be possible. you'll have to check engine mounts first though. i can't think of any reason why it wouldn't though. it'd be a good swap, 100bhpish and fair amount of torque i believe?
LittleBuda New member Joined May 7, 2008 Messages 5 Points 1 Location Zagreb May 8, 2008 #3 1.6 engine goes in to tipo whitout problem but electrical wireing is problem,you have to take all wires from marea and ECU,then apply it to tipo. few months ago we apply 3.0 V6 from alfa romeo 164 to tipo and if that is possible than this is easy
bluejohn125 Patron member Parked in the garage Joined Aug 11, 2004 Messages 1,825 Points 418 Location Wirral May 13, 2008 #4 I always thought that the easiest upgrade for a 1.4/1.6 Tipo would be to fit the 1.6 MPI 90Hp engine from the Mk1 punto sporting / cabrio. As far as I am aware it is basically an improved Tipo 1.6 motor, has anybody done this? Should go more or less straight in.
Hellcat zombie nation Parked in the garage Written a guide Joined Jul 8, 2005 Messages 28,517 Points 5,262 Location on the A684 May 13, 2008 #5 Tipo engine cradle is pretty much the same as the Bravo/Marea/Coupe so engine mounts are always going to be there or there abouts. Last edited: May 13, 2008
