Right had fault code p105 map/baro circuit malfunction fault come up...
fitted new map and it still does it...
cleaned out inlet manifold and it still does it
what happens is after the engine fault code comes up the car eill not hold a steady idle... it will run but as soon as you let of the throttle to idle it will hunt and bonce from 650-1000rmp then die...
as soon as you reset the fault codes it runs perfect.. untill it kicks off again.. which can be anything frrom ten mins later to 48 hours later....
any ideas...???
any ideas...???
