anth New member Joined Apr 28, 2005 Messages 118 Points 39 Apr 15, 2008 #1 any one know if a 04 punto engine would fit in a 2000 punto. stick lnform me if your on here or anyone else.
R Raducu Member Joined Apr 3, 2008 Messages 315 Points 72 Location Cluj-Napoca Apr 15, 2008 #2 i think mk2 04 8v 16v equals 00 8v 16v difference is mpi spi, but i am not a pro
The Sultan Bravo 1.8 HLX FTW Written 5 guides Joined Jul 28, 2006 Messages 4,217 Points 736 Location lake windermere east edge Apr 15, 2008 #3 Raducu said: i think mk2 04 8v 16v equals 00 8v 16v difference is mpi spi, but i am not a pro Click to expand... not quite the only difference is emissions regulations at the time meaning the size and shape of the ports are different n the head both engines have mpi but the 00 have grouped the 04 have sequential and finally 0 has crank sensor only 04 has crank and cam or phase sensor no mk2s have spi only mk1 i'm afraid the engine it's self will both run fine with each others ecus but but you will have to swap some covers and cam pulleys for the extra phase sensor
OP OP anth New member Joined Apr 28, 2005 Messages 118 Points 39 Apr 15, 2008 #4 and wat covers may these be may i ask rocker,inlet outlet
The Sultan Bravo 1.8 HLX FTW Written 5 guides Joined Jul 28, 2006 Messages 4,217 Points 736 Location lake windermere east edge Apr 16, 2008 #5 anth said: and wat covers may these be may i ask rocker,inlet outlet Click to expand... yes rocker cover for the sensor the inlets would have to stay with the engine but either throttle body could be bolted to them and injectors could be swapped as they are different i asume exhaust manifold will have changed too just need to have a look at some really and see if there is any difference in the shape of the ports
