Pandarus Prominent member Parked in the garage Joined Dec 5, 2005 Messages 2,849 Points 535 Location Sleepy Suffolk Feb 27, 2008 #1 My driver's door has become a little stiff / almost sticky on opening lately, any ideas? Is it possible to get wear in the door release cables?
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 27, 2008 #2 Pop the handle out and see whether its the handle or the mechanism thats sticky. Cheers D
A andre88uk Patron member Joined Jan 4, 2008 Messages 276 Points 56 Location Great Yarmouth Feb 27, 2008 #3 Spray the hinges with wd40 ? and then take the door cards off and spray around the door cable
OP OP Pandarus Prominent member Parked in the garage Joined Dec 5, 2005 Messages 2,849 Points 535 Location Sleepy Suffolk Feb 27, 2008 #4 It opens from the inside ok but is 'sticky' / heavy when i open it from outside. I need some light and some time to look at it.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Feb 27, 2008 #5 Look just inside the door edge at the same height as the handle. There you will spy a screw that seems to be in an odd place. Undo, and the handle will slide back, then out. Cheers D
