Hi guys,
I have a 1997 Punto 1.2, SX60.
The past couple of days the car's gears have felt a bit weird. The engine would be loud in 2nd gear so I would go up into 3rd and the car would kinda slow down! And the engine would still be noisy. I would have to accelerate a lot. Now I didn't think too much of this because the route I take to work has a lot of upward slopes and I know if you go into a higher gear too early on a slope it makes things worse.
I should probably mention that I have a habit of staying in 2nd when I should be in 3rd, if I am going through 2 roundabouts that are say 300m apart I won't bother changing gears. Maybe this has damaged my car?
This morning the car cut out about 7 or 8 times. The traffic was mad and I was stuck on a steep hill for ages and the road was wet. I thought maybe it was my hill starts that were at fault and maybe ti was because the road was so wet. Then I was on the Belgard Rd which only has a very small slope, I rarely need do do a hill start. The car cut out another couple of times. Very frustrating!
I parked the car and when I came out on my lunch break and started reversing it out of the space I heard a squealing noise. Like the noise the kettle makes when it's boiled! I drive to Halfords, I'm going round the car park in 1st and the car is squealing. I move up to 2nd and soon it starts squealing again! I also had to accelerate more than I usually would need to.
I am raging, this is literally the first day this has happened but I am fuming, I don't have the car very long and I'm scared it will cost me a fortune to get fixed!!! What could be wrong??? There not too long ago the car used to make a noise when I accelerated which turned out to just be a couple of loose nuts on the wheel. I am hoping to god this is the same, just something small that is loose, but I am raging! I am also terrified the car will break down on me tonight on the way home, I wouldn't know what to do!!!
