Hi guys! I have question Maybe You can help me to find FIAT PANDA 100HP 1.4 16v AIR INTAKE PIPE, part # 51773405. Found only new one for €188 ;/ Maybe some of You have used one? Thanks in advance.
The engine breather tube will be hardened and cracking. The air intake is specific to the 100HP. Both could be assembled with silicone hoses and metal tubes from ASH https://www.autosiliconehoses.com
The standard intake collects air from the front grille so its likely to be as good as it gets for air flow. The built in plenums reduce boom noises at gear shift points.
If yours is too mangled to use just take measurements from the filter case intake and get tubes/silicone to suit. Bear in mind that for a given air pressure, doubling the pipe diameter gives 16 times the gas flow.
