Hello community! I open this topic with the hope that I will be able to find a solution to a problem.
I own a Fiat Panda 169 2006 1.1 and the position on the left side does not work (neither in front, nor in the back).
From what I noticed on the streets, I'm not the only one with this problem (I know of at least two identical models with the same issue).
I checked the bulbs, fuses and relays, the easily accessible plugs and cables, the motherboard where the plugs go (under the steering wheel) ...
I don't know what to do now. I thought the problem could be with the computer or the motherboard mentioned above.
What do you think? Do you have any ideas? Do you know the solution?
I would be grateful if you could help me!
Love you all and thank you in advance! :slayer:
