FIAT Auto Specialist Team
Old 08-06-2021   #1
Greece
panda 4x4 2005 1.2 8v what engine ?
hi i want to buy a panda 2005 4x4 and i see that from 2004-2010 this engine produces 60 hp ...is it the 1.2 8v spi that i used to have in my sei ? that engine was also 60 hp ..does the same parts fit in panda 4x4 engine ? i had install the punto 75 cam and exhaust manifold and thortle body with very good gains and no problems till i sell the car ....any help on engine tuning ?10/15 ps will be more than welcome
mozart is offline Reply With Quote Quote
Old 08-06-2021   #2
Re: panda 4x4 2005 1.2 8v what engine ?
as far as a know. No
just to change the exhaust manifold for the Puntos requires major modifications
the studs are different sizes and the connection is different
which involves drilling out the holes and welding
throttle body maybe. Sometimes they work. Sometimes not. Someone did two cars. One worked fine. The other didn't. Probably depends on the ECU version
why
even the 69HP isnt any better. What you gain at High revs you loose at low and for a 4x4 it low down that counts
Likes jrkitching liked this post
koalar is offline Reply With Quote Quote
Old 08-06-2021   #3
Moderator
Quote Originally Posted by koalar View Post
The 60HP engine actually has more power & torque below 3500 than the 69HP one.
On a road car in general use, driveability is much more important than absolute peak power; perhaps even more so on a 4x4.
Personally I wouldn't contemplate this; if the 60HP engine isn't giving you the drive you want, buy a different car.
I'd take a 60HP Euro 4 Panda over a 69HP Euro 5 one, every time.
Likes koalar liked this post
"Just 'cos you're not paranoid, doesn't mean they're not out to get you"
jrkitching is offline Reply With Quote Quote
Old 08-06-2021   #4
Trader Rating: 1
portland_bill has donated!
I've often thought that what the Panda needed was the 1.4 8v, 80hp engine. More power than the 1.2, not so lively as the 100hp. I think that might go well in the 4x4 too.
Likes The Panda Nut, MrMagoo, jrkitching, koalar liked this post
13 years motor trade, 16 years motor industry. 17 years Driving Instructor & 10 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 09-06-2021   #5
Greece
amazing that this engine is un tuningble .... i wanted to buy the diesel engine but is 2000e more .. a very good local tuner told me that he can reprogram the ecu but for very small gains ....the punto 75 cam ? or reprofile ? why my cento engine 1.2 spi was so tuning friendly and this is not ? just for little better open road trip
Old 09-06-2021   #6
Quote Originally Posted by mozart View Post
It tuneable
but
its not straight forward
its not cheap
here in the UK your starting with a 700 car that 17 years old you can take it up to 200 BHP by adding a turbo and throwing money at it
But you could just start with a Corsa b 16v which is good for 200 bhp on standard internals
170 approx vernier pully
350 approx fast road cam
600 approx forged pistion
3rd party ECU
larger injectors
Turbo
and so on
easy spend 4x 10x the price of the car
or you could change the exhaust so it sounds better.
or just buy a 100HP which would be cheaper
Old 09-06-2021   #7
Greece
i already have a clio rs 2010 and an alfa 145 qv but if i manage to give the 4x4 something more i will do it
Old 09-06-2021   #8
or start with the 1.3 same price to buy
remap quote 111bhp and 176lbft on standard boost
Old 09-06-2021   #9
For potentially the cost of return postage just get this. It it's no good just send it back.
https://www.ebay.co.uk/sch/i.html?_f...42711&_sacat=0
It will need a catalyst under the floor. Talk to these guys -https://www.ebay.co.uk/usr/mijexhaust?_trksid=p2047675.l2559 who could supply a larger cat to place under the floor and modify the ends to fit your needs.
DaveMcT is offline Reply With Quote Quote
Old 09-06-2021   #10
Quote Originally Posted by DaveMcT View Post
not a straight fit for a Panda
different stud size
different last bend
flange fitting
pushes the power band higher up the revs
pointless as a mod on its own
Old 10-06-2021   #11
Moderator
Agreed. Once you've put a cat on, the benefits (if any) will be negligible.
It's all been said already. For normal everyday driving, the 60HP FIRE is a great engine straight out of the box. Most modifications will end up making it less flexible and will likely reduce performance where it matters most.
Old 10-06-2021   #12
these guys are getting over 100 hp on standard internals and a carb
http://www.750formula.co.uk/forum/vi...2cb2314b25dde1
however that at 7500 RPM and race cam
Old 11-06-2021   #13
Trader Rating: 1
The link, sadly just takes us to a main page, so would have to search for the particular thread, with little to go on.
However, whilst a race-tuned engine might be exciting at times, popping to the shops might be a real pain.
Likes The Panda Nut, koalar liked this post
Old 11-06-2021   #14
Quote Originally Posted by portland_bill View Post
I didn't have enough interest to link all the pages.
loads of information all over the forum
there is a rolling road printout with 110BHP
its a very limited formula in what mods are allowed
pistons, rods, Crank, flywheel are all factory parts
cam is made for the formula
inlet and exhaust are free
Old 12-06-2021   #15
Greece
i think in the formula is the spi engine not the 4x4 mpi
(T) panda 2005 1.2 4x4 cold engine tage1954 Panda 2 19-01-2014 15:59
