Hello everyone!
Sorry if this has come up before, I know there are some (almost) similar cases as mine, but I haven't found any solutions so far.
I have a '11 Panda Van 1.2 8v (the 69hp version, code 169A4000). The car is driving fine, no other problems apart from the pulsating/hunting idle. It's not noticeable when no auxiliaries are switched on (or at least I'm not sensitive enough), but the lights and fans on (especially the lights), it gets much more prominent. It seems like that it has an even interval (~3 sec), it drops to ~500 rpm then back normal. It ticks over nicely, then drops again. It never stalled though. Now I know there might be some electrical load issues but what's odd is that this only started to happen AFTER I cleaned the throttle body. (Took it off, cleaned with carb cleaner, reassembled, also did an oil and filters change). Before that the idle was perfectly fine, I just noticed that gunk had built up on the butterfly valve so I thought why not.
I checked diagnostics (not MES though), no error codes at all. Took the airbox off, I can see the butterfly valve moving while idling. It starts to close, rev drops, then it opens, rev goes back to normal. It seems to me that the ECU doesn't know the correct position (or there is some sensor giving wrong info)?
I cleaned the breather hose (was dirty inside, but no blockage I think) also cleaned the small diameter breather hose going from the airbox to the lower part of the intake manifold (which is blocked by the way, so the hose is not doing anything apparently). They aren't split, also tried pulling them off while idling, blocking the airbox ends of the breathers, no difference. Cleaned the MAP sensor, no difference. Did an ECU reset, no difference. Battery also seems to be fine. I've been using the car for about 2000 kms since then, so it won't adapt probably. As this engine is drive-by-wire there is no idle control valve, at least I haven't found it.
So my question is, might be that it needs a throttle relearn procedure I'm not aware of? I've read that there might be but there are also contradicting info regarding this procedure. It would be strange if suddenly some other sensor went haywire at the same time when cleaning the TB. Also I don't think I broke the TB as it's working perfectly at any other point in time.
Things that were changed last year so should be good:
- spark plugs
- ignition coil and leads
- upper lambda probe
Might be TL;DR, anyways, thanks in advance!
Ivan
- spark plugs
Ivan
