- Nov 6, 2008
- 65
- 30
Hello
I have a 2009 Panda 1.2 which I need to replace the battery as its fading and after charging it looses it charge.
Problem is the various sites I have looked at to put your reg number in come up with a smaller sized battery than the existing one, the one in the car measures L207mm D175mm H190mm these measurements are taken as looking at the battery in the car.
The batteries that show on sites as a replacement are size L175mm D175mm H190mm the depth and height are the same but the length is much shorter, should I just look for the same Ah & CCa spec and not worry about the length.
Thanks for any info.
