- Jan 23, 2021
- 2
- 3
Morning all,
Mr Panda only came with one key, and it's pretty worn; the door locks and ignition are a particular issue. I've bought a replacement set of barrels with two keys in order to replace them. The doors and tailgate look quite simple; lots of how to guides online. The ignition barrel looks more tricky...
Having removed the trim and consulted the Haynes, it seems the whole steering column needs to be stripped and the shear bolts drilled out. One thing I noticed was a sensor on a plastic ring around the ignition barrel. With this removed the car won't start. I assume it's linked to the immobiliser?
The key is a standard blue plastic Fiat key, no sign that it has a transmitter or a battery compartment. Does the ignition sensor detect the presence of a key, the particular matched key, or just the position of the ignition switch?
Thanks, have a great weekend.
