- Mar 16, 2017
- 62
- 22
Hi,i have a 07 panda never lacks for anything, ie parts if required..It has 118 thousand on the clock., at 112 thousand it had new full clutch LUK, slave cylinder LUK plus gear box oil changed. Just recently it has been a bit reluctant to select 1st or reverse, turn engine off no problem. When in engine bay and someone operates the clutch you can hear a type of slurping noise near gearbox. There is no loss of clutch fluid. My question is as anyone had a slave cylinder go after 6 thousand mile, plus if the garage put wrong spec oil in gear box would this be the problem? Any help most appreciated.. Ps 1.2 petrol (not a boy racer) Thank you.
