- May 30, 2020
- 16
- 3
Desperately need aNon abs brake master cylinder
Part Number is on the label stuck to the front as is the make. Is it a Bosch
There's about 8 different part numbers but I suspect they will all be the same
What appears to be the problem with it. I haven't seen on fail yet !
I received some more information from the OP
I had all brakes done with other things.The brake light is on continuely.The milage flashes on and off.All this has happened since brakes being done.My mechanic tells me I need aBrake Master Cylinder
which other might have ideas on
sound more like the brake switch needs adjusting to me
the reason I questioned the 500 is because they were produced after ABS was compulsory
I thought by 04 all Fiats had ABS but maybe wrong either way it looks to me you need a different mechanic ??
ABS became compulsory around April/May 2004, so vehicles registered before that might not have it. Most manufacturers will fit new stuff early, and Fiat are usually good at that, so looks like this one sat around unsold for longer than most. Any issues causd by that will have been sorted long ago.
