TN9's are'nt really designed to run in oil as additives in some oils can effect the cage.
https://www.rmbearings.co.uk/pictures/pdfs/FAG%20CAGE%20TYPES.pdf
I don't know where you are based, but have you thought about contacting a local bearing supplier?
Tell them what you want and what for.
I'm sure they'll know exactly what you need.
Thank you most useful graph. Which has put my mind at rest
Following the gear oil line off the right hand side of the graph until it reaches say 60 degrees its well over 100,000 hours and many more as thats at a constant temperature. It going to be below 35 degrees for most of its life
Looking at the classic car forums where they have to rebuild their gearboxes as replacements aren't available
Say Fiat / Bertone X1/9
The right input shaft bearing, Fiat 4402118 - SKF NJ2/22 TN9 (22x50x14) is dimensionally identical to the four speed equivalent (Fiat 24901150 - SKF 62/22 also 22x50x14) but the later gearbox bearing is a roller bearing as opposed to the ball bearing of the earlier gearboxes...this Fiat number (4402118) also superceeds to Fiat 5947020
Which does mean an upgrade to our box's is also possible although I will not be going down this route.
For my own curiosity I would also like to know the reason for a glass reinforced cage at the input end only as its 3x the price. Been looking through lots of gearboxes and its usually the input end only and the other end is metal cage. If a manufacture could save a few quid per car they would. After all it mounts up if you are building million
"Cages made from glass-fibre reinforced polyamide
PA66-GF25 are now used in numerous large-series
bearings. A high degree of elasticity, a low weight as
well as good sliding and dry-running properties have
a positive effect on the bearing service life"
There has to be a clue there. I guessing it keeps the input shaft wiggle down for longer ?? Maybe noise or economy ?? I don't know.
