im Axle Specialists
Old 3 Weeks Ago   #1
Rear brake shoe self adjusters
A second question please,
can anyone tell me where the 2 washers that are supplied with with these adjusters actually fit?
https://www.ebay.co.uk/itm/PAIR-REAR...53.m1438.l2649
thanks again
tonyn is offline Reply With Quote Quote
Old 3 Weeks Ago   #2
Re: Rear brake shoe self adjusters
Wow there expensive
I now buy them ready assembled kits with shoes, slave cylinders for around 50
I don't remember seeing those washers on the Bosch I have taken off
The adjusters are generic
Same ones used in Citroen, Suzuki , Vauxhall and so on maybe for other fitments
Maybe someone else can confirm
koalar is offline Reply With Quote Quote
Old 3 Weeks Ago   #3
rmjbn1 has donated!
I can only imagine they're supposed to go over the adjustment screw between the ratchet wheel and the link rod of the adjuster?
Mine definitely don't have those washers fitted anywhere.
rmjbn1 is offline Reply With Quote Quote
Old 3 Weeks Ago   #4
chris3234 has donated!
They go between the threaded road and the main body of the adjuster
My 500 has washers like those on
Thanks koalar thanked for this post
chris3234 is offline Reply With Quote Quote
Old 3 Weeks Ago   #5
Quote Originally Posted by chris3234 View Post
strange. Do you think the adjusters might have been changed in the past
might be a new thing but i have changed several around 05/06 mark without any.
not on the 500 instructions. But they might have been an update
http://4cardata.info/elearn/312/2/31...0002/312002280
Old 3 Weeks Ago   #6
You can zoom in on the ones I buy there's no washer
https://www.eurocarparts.com/p/pagid...-kit-122580038
Shop4parts doesn't appear to have them either although a little dark to see properly
Under the part number 77362613 most people don't supply a washer
For some reason most eBay suppliers do?
Old 3 Weeks Ago   #7
The washers are for the LOCKHEED brakes
Not sure where they fit as all the Pandas I have seen have been Bosch
Old 3 Weeks Ago   #8
Trader Rating: 1
portland_bill has donated!
Quote Originally Posted by koalar View Post
Not got washers on my 2006.
If the originals have washers, that'll show where to place these, if not, don't fir them.
I'm intrigued by them being on Lockheed brakes. The Lockheed brakes were the early, non-ABS models, so quite rare with less than year production, but I thought the Lockheed had manual adjusters, so no need for these self-adjusters. Doesn't matter really, just don't use them unless yours already has them.
13 years motor trade, 16 years motor industry. 16 years Driving Instructor & 9 years Fleet Trainer
Panda Alessi (2015 Skoda Fabia)
portland_bill is offline Reply With Quote Quote
Old 3 Weeks Ago   #9
Thanks to everyone for the replies and info.
Will have to go back and strip it all down , re-assembly and see how that pans out.
Old 3 Weeks Ago   #10
I am concerned that @chris3234 has them fitted
The adjusters are quite a clever minimalist design. Even the little spring that holds the adjuster is a little off square on purpose to add a little gap
Having a washer into the mechanism will effect its performance
Even though I don't know where it should go complete assembles with the adjuster and springs ready fitted have 4 pins 4 clips and 2 starlock washers separate
Old 3 Weeks Ago   #11
Perhaps it was the spring washer/clip on the threaded end I was thinking off
Hard to say as it was nearly 2 years ago and no longer have the car
Old 3 Weeks Ago   #12
You can get special pliers on eBay for under 10 that compress the brake pad retaining springs.
DaveMcT is offline Reply With Quote Quote
Old 2 Weeks Ago   #13
Are we all sorted ???
Old 2 Weeks Ago   #14
Koalar, yep sorted.
Priced up the ready assembled kit against buying everthing individually, and time saved
Got the ready assembled kits
Job done.
Likes koalar liked this post
(G) Rear Brake adjusters kat7 Marea 17 17-01-2018 08:15
(T) Brake shoe adjusters Si78 Panda 11 30-10-2017 17:42
(T) Changing Brake Shoes - Unsure About Shoe Adjusters woodbine66 Scudo 2 26-11-2015 23:22
(T) rear brake self adjusters mickyw Punto (Mk2/2b) 5 14-09-2014 18:08
(T) Rear brake shoe adjusters frozenfiat Scudo 0 21-05-2014 22:42
