Old 03-10-2020   #1
Rear brake adjustment adjustment
Hello all,
2004 1.2 ,ABS.
I have hade to change the rear nearside brake drum.
When ive fitted the new drum, its so tight, it nearly impossible to turn it.
To adjust the brake shoes inwards , to free it up, do i turn the cogged wheel on the adjuster upwards or downwards?
tonyn is offline Reply With Quote Quote
Old 03-10-2020   #2
Re: Rear brake adjustment adjustment
There self adjusting but need some slake in the handbrake cable to work properly
Wind them fully in and put the drums on
slacken handbrake cable by at least three turns
forcibly press the brake peddle loads of times clicking stops
retighten the cable
make sure the rear wheel rotate freely
check the handbrake action starts before the First notch
make sure the handbrake doesn't past the fifth notch
Its easy. There is too much false information floating around on the internet and YouTube
Likes rmjbn1 liked this post
koalar is offline Reply With Quote Quote
Old 03-10-2020   #3
Quote Originally Posted by tonyn View Post
Hello all,
2004 1.2 ,ABS.
Its different for each side. Ones left hand and one right hand threaded
Just wind them both fully in by hand
If the drum doesn't fit easy you have assembled something wrong.
Old 03-10-2020   #4
Thanks Koalar,
To wind it fully in , do i send the cogged wheel upwards or downwards?
Old 03-10-2020   #5
rmjbn1 has donated!
Ireland
I agree with koalar, the handbrake adjuster needs to be slackened first, then re-tightened at the end. It's underneath the handbrake housing inside the car (4 bolts to remove).
I would also prise the shoes out and manually wind the automatic adjuster back.
The cogged wheel is a ratchet - it can be forced the wrong way to loosen it, but I don't think it's a great idea, the ratchet wheel is quite soft and easy to damage.
Thanks koalar thanked for this post
rmjbn1 is offline Reply With Quote Quote
Old 03-10-2020   #6
The adjuster fit in slots. Its easy to fall out of one side
Should be horizontal to the ground.
Old 03-10-2020   #7
Thanks Koalar,
You need to lift the latch and turn it so the bar shortens
From memory down but don't quote me
I don't really think about it as I wind them fully in before I assemble the rears
Old 03-10-2020   #8
Quote Originally Posted by rmjbn1 View Post
Agreed. The cog is soft you have to lift the spring steel latch first
Old 03-10-2020   #9
rmjbn1 has donated!
Ireland
Quote Originally Posted by koalar View Post
Yes, I'm pretty sure it is down. You'll know as soon as you try - because you'll be forcing it against the ratchet pawl it'll be much harder to turn in that direction without prising the pawl out of the way first.
You might also be able to tell from close inspection which side of the teeth are sloped on the ratchet wheel.
(T) rear brake adjustment MTD Qubo 6 17-07-2020 14:23
(T) Rear brake adjustment rbulkley 127 2 09-07-2019 09:42
(T) Rear Brake Adjustment FM02MZO Ducato 16 12-06-2017 13:21
(G) brake adjustment on fiat brava (rear) gorilla161 Bravo / Brava 4 29-06-2011 12:21
rear brake adjustment paul smith FIAT Boo Archives 4 16-08-2001 09:56
