So I'm thinking of fitting a small switch between the ignition barrel switch to power the starter motor to start the engine and the supply to the starter circuitry so that when switched off the key can be turned to the on position with no effect but when turned to crank position nothing happens unless switch is in the on position acting as a manual imboliser and preventing engine starting so helping prevent theft (atm this is just an idea so looking for advice help etc)
