Old 1 Week Ago   #1
Manual
Hi I need to carry out some repairs on my pander anyone know the correct Haynes manual for fiat pander easy 5 door 2013
steve gray is offline Reply With Quote Quote
Old 1 Week Ago   #2
Re: Manual
Quote Originally Posted by steve gray View Post
Wrong section for the 2013
The Haynes manual for the 169 is pants in my opinion.
To give you a couple of examples. Most of the engine management wiring is missing, the most important part. Some of the torque values are wildly wrong.
There are nowhere near as good as they use to be
You should be able to find a version. Of the eLearn on the Web somewhere. Try searching polish forums 😉
Takes a bit of setting up I use a vertical drive to emulate a CD drive on my tablet
koalar is offline Reply With Quote Quote
Old 1 Week Ago   #3
Re: Manual
Hi Thanks for your comment and no disrespect meant but Iím 70 and donít know anything about virtual drives etc Iím simply looking for a straight forward manual that will show me where and how to access the heater matrix in my fiat panda easy 2013
Old 1 Week Ago   #4
Re: Manual
Haynes doesn't do one past 2012
This section of the forum is for up to 2012
Although similar they are also quite different
Best posting in the post 2012 section
On a 06 it involves
Disconnect the battery
Drain the coolant
Pop out the passenger airbag switch from the glove box
Remove the glovebox
Remove the passenger side dash screws just the ones underneath
Loosen the passenger airbag. Cant remember if there is also a screw under here but you don't have to disconnect it pop it back in place loose
Pop up the plastic ring holding the gear gaiter down
Lift out the section underneath
Remove the screws holding the gear lower trim in place
Remove the trim its tricky as there are also clips left side is always easy right side always fights you
On the left side there it a Black cover held on with tiny bolts remove.
You can now see the matrix and a plastic joining pipe
Remove the one screw and nut holding them together
In the engine Bay disconnect the two hoses. You will have to break the clamps off and replace with new clips
Remove the bolts holding the Black plastic cover down and pull the plastic pipes out
Inside the car pull the matrix out while lifting up the dash
Its a very tight squeeze but just doable without taking out the dash out fully by giving it enough wiggle room
Its been a few years so may have missed something out
Thanks steve gray thanked for this post
Old 6 Days Ago   #5
Re: Manual
Pandamime did a "How to video" for removing the dash from a Panda 169. He's only taken out the plastic, not the whole steel tube structure beneath, but it should allow access for changing the heater fan speed resistor and may well improve access for the heater matrix. Just beware the steel structure underneath has razor sharp edges.
https://www.youtube.com/watch?v=1-G6rwnRQFI
BUT have you checked the "Duck Bill's". These are the drain tabs for the air intake plenum beneath the windscreen wipers. They clog with dirt and can get bad enough to collect rain water that runs into the car.
DaveMcT is offline Reply With Quote Quote
Old 5 Days Ago   #6
Re: Manual
ok can anyone tell me where and how to access the heater matrix on my fiat pander easy 5 door 2013 I've been told I don't have to take out the dash to reconnect the Bowden cable to the heater box
Old 5 Days Ago   #7
varesecrazy has donated!
Re: Manual
Replied..
(T) Free download service manual workshop manual 1978/79 Spider please? slimlavud 124 Spider (Classic) 1 02-11-2019 00:15
(G) Fiat Stilo service manual, repair manual and workshop manual Old Hippy Stilo 38 02-12-2017 21:47
(T) Where to find Doblo Cargo electronic/PDF User Manual & Repair Manual RufusG Doblo 3 09-01-2017 18:03
(T) My manual 2013 Fiat 500 1.2 manual drives as an automatic Nordboj 500 9 11-09-2016 08:17
New Croma manual and blue&me manual in english or greek goalouzo Lets Talk FIAT 2 27-08-2009 10:34
