Hi all
The MiL has had an 08 Panda 1.2 (169) for years but the window now only goes down a few inch before it stops and farts at her.
I have done a few searches on here and other places but not many mention these type of noises. They mention cracking, not brrrrrring and farting.
On a few searches it mentions cutting a plastic clip off. I have looked and the only thing I can see that is plastic is already broken (see pics) and can not see how cutting it will help.
I have had a good look to see if anything is jamming down the side channels and can not see anything, plus the window will go down if I give it a push. It then gets stuck about halfway and I have to push it down. It also gets stuck halfway up and again a few inches from the top. And always in the same places.
Here are the pics. GFo to imgur and add /a/MgZEe7b.
Can that one little broken bit cause all the noise?
And here is a video of it sticking and the farting noises.
Edit:FFSorry will not allow me to post links. I can send you a shareable link to the noise if you want it.
I don't mind doing the repair. I just don't want to buy a regulator if it is the motor. Or if it is a cog etc. I want to do it properly first time.
Any insights are much appreciated.
