- Feb 28, 2016
- 767
- 215
Hi Guys
option 1.
in my book would be to find a set of the torx bits and use the one that is an interference fit into the sump plug, tap it in. the main benefit of this is they grip in the corners.
option 2, would be to schedule in a full replacement sump/gasket and sump plug, at the point of the oil change, your existing one probably has corrosion on the surface so good opportunity.
Tim
option 1.
Tim
