- Sep 14, 2009
- 19,492
- 3,294
I've probably made the rookie mistake with canbus spot lights but can anyone confirm?
Before I waste hours belling out the car loom for a non-existent fault, can anyone confirm if the canbus expects to see a halogen bulb load?
100HP OEM front spot lights were rusty with blown bulbs so removed for MOT. There was no bulb fault warning. The panel switch works and warning light appears on dash.
I dont want another set of OEM lights which will rot just the same. Instead fitted LED spot lights which tested out fine on the battery. However they dont work when plugged into the car wiring (I used the correct connectors).
