Old 03-05-2020   #1
France
1.2 consuming too much fuel
I have changed the throttle body and all injectors problem is still there, it has poor acceleration also, obd scanned , no faults regarding ignition . On deceleration ( from 2000 and above rpm) rpm goes to 1000 and rises again to 1200 then goes back to 800 ( while raving car in neutral)
Chali is offline Reply With Quote Quote
Old 03-05-2020   #2
varesecrazy has donated!
Re: 1.2 consuming too much fuel
Have you had the exhaust emissions tested?
How do the tips of the spark plugs look??
Old 03-05-2020   #3
France
No i havenít tested, tips are dark brown
Old 03-05-2020   #4
Sounds like overfuelling..
But you need to discover why
Old 03-05-2020   #5
France
O2 sensors are fine too, what could be reason, i have poured injector cleaner in fuel tank also . I have two pandas 1.1 and 1.2, 1.1 is new gen motor ( new head ) 1.1 drives alot better , i dont know the reason why
Old 03-05-2020   #6
I'm certainly not a guru on all things Panda, but I've read plenty on here about a failed thermostat being common.
Have you checked what temperature your engine is running at, as I'd think an open 'stat would cause it to run rich ?
Panda Dynamic is offline Reply With Quote Quote
Old 03-05-2020   #7
if you rattle the air filter do the revs alter ?
koalar is offline Reply With Quote Quote
Old 04-05-2020   #8
France
Quote Originally Posted by koalar View Post
No
Old 04-05-2020   #9
High revs at tickover suggests air leaks. What if the service/breakdown history of the car?
DaveMcT is offline Reply With Quote Quote
Old 04-05-2020   #10
France
Quote Originally Posted by Panda Dynamic View Post
If it is stuck open it should remain cold, after 10 minutes of driving it goes to NOT ( Normal operating Temperature) guage stays in middle. I have recently changed its timing belt and water pump also. Can the ignition coils be culprit ?
Old 04-05-2020   #11
Miss firing coils will usually raise a fault code. But a small missfire will cause the engine to run rich. O2 sensors see the unused oxygen so ECU responds by adding more fuel.
The first test is to make sure engine reaches normal running temperature.
Old 19-05-2020   #12
Hi Chali
Are you certain that the cam timing is spot on since the timing belt was changed, just incase its one tooth forward or backward.
Tim
timmycm850 is offline Reply With Quote Quote
Old 19-05-2020   #13
Quote Originally Posted by Chali View Post
No
Any progress..?
Old 20-05-2020   #14
Quote Originally Posted by timmycm850 View Post
Hi Chali
Tim
sounds like a sensible suggestion to me
Old 20-05-2020   #15
Belt timing:
The basic motor can run a few teeth out.. (but not 7..!!)
not sure about later VVT 's though
(T) Fitting fuel pump sender assembly back into fuel tank?! chlblnz Panda (Classic) 4 30-05-2013 13:43
(T) Fuel Guage Reads Quarter More Than Fuel In Tank - 2004 2.0 JTD whitespirit66 Scudo 3 31-03-2013 23:44
(T) Engine won't start - Low fuel warning but loads of fuel Kwayley Grande Punto 12 05-09-2011 17:26
(T) consuming oil amen 500 13 13-11-2009 17:59
D.I.Y Project Consuming My Life! twincamms Leisure Lounge 50 11-01-2005 18:06
