I will look here in another 2 weeks..
Hi,So i adjusted timing again, put new spark plugs, new thermostat valve, interchanged 02 sensors and checked brakes as well. After sparks plugs the consumption decreased, but still it is giving 8.5l/100 km (26.7 mpg )
What could be cause, i did compression test also, all cylinders are between 210psi to 220 psi , which means engine is ok.
I am fed up with this tiny 1.2 litre 60bhp engine which is consuming like 200 bhp
and the mpg if you disconnect the MAP
Dont know, but engine starts vibrating, very rough idle,
What is your daily driving like, are you driving 10 miles down the road on every trip at a steady 80kph or are you sat in bumper to bumper traffic on the morning commute creeping a few metres at a time and burning a tank load of fuel while hardly moving ?
Did these problems exists from when you bought the car or are they something that has developed while you’ve owned it ?
City mix driving, even that should not give me 220 miles for a full tank of petrol. Acceleration feels underpowered if compared to other pandas, engine is also louder than other pandas. I had 3 pandas , thats why i can relate.
I have multimeter, i will check the leads, what should be normal readings for good wires .My wife does short runs (3 to 5 miles) but minimal traffic gets about 40 to 45 mpg (dont know what that is in L/100Km). I take it out for a fast drive every now and again.
A missfire (even barly perceptible) will increase fuel consumption. The ECU sees the unused oxygen and feed more fuel to compensate, often making the missfire worse. Weak coils and plug leads can be enough especially on wasted spark systems. Check the coil resistance values.
45 mpg is excellent, mine is giving 27 mpg, or should i just put new coils, map sensor, leads.My wife does short runs (3 to 5 miles) but minimal traffic gets about 40 to 45 mpg (dont know what that is in L/100Km). I take it out for a fast drive every now and again.
Or you could post photos of the cam shaft lobes of cylinder1 and cylinder4 with crank set at 0 degrees tdc.45 mpg is excellent, mine is giving 27 mpg, or should i just put new coils, map sensor, leads.
