General What's ur best MPG?
Mousendahouse
Hello everybody. Im curious what is ur best MPG (and ur engine ofcourse)
If u got some good eco tips please do share (y)
Actual MPG, not from trip computer...
49-56 for a 55 plate Dualogic 1.2
76-79 for a 55 plate Multijet 1.3
Both rural driving (fairly gentle, but not holding up traffic, no trips under 10 miles), Nokian iLine tyres, supermarket fuel, driver only.
32-35 for a 07 plate 100hp A & B roads. (Not so gentle, being held up by traffic!), RainSport3 tyres, supermarket fuel, driver only.
Live in Norfolk, so no motorways and precious little Dual Carriageway.
10 years with the Panda 1.2 60hp has given me an annoying average of 49.7. 50 would be so much nicer.
Currently, with so little traffic, it is returning 53-54. Others report better, but being based on the Eleganza, the climate control is running all the time which will reduce the economy a little. Most journeys are not local, so much is motorway, and at 70, consumption is rather worse than on A & B roads.
The working car, A 2015 Fabia 1.2 TSi, just keeps giving low 50s, even with learners driving. A recent couple of trips of 40 miles each way, mostly B-roads, returned 63mpg. Heavier car, faster, yet better than the 14 yr old Panda. Progress. (Still enjoy the Panda more)
Road surface, wind direction, temperature.
Best ever was Crewe to Norwich with a strong tail wind @ 68 mpg
Really need to keep top speed below 55 mph. Around 50 seems to be a sweet spot.
there's one road near me thats has a very rough surface thats terrible for mpg
you'll do well to get into the mid 50s on it.
1.2L 05
I don't find a modern Suzuki any better. The 16v engine just doesn't have the same low down power.
Panda Waze 4x4 doing 42mpg driven mixed trips. 50 attainable on a long run wihtout much care but only 5000 miles so far- summer tyres in the summer months. So far only 1000 miles on winter tyres.
Panda 4x4 0.9 - 37mpg winter tyres average driving and mixed roads over 18000 miles.
Panda 100 43 mpg driven fast all the time over 80000 miles 46mpg with a little effort. On a long run 50mpg driven within the speed limit. On its last day with me absolutely flat out Norfolk to Manchester 50mpg.
312 1.2 lounge gives easy 46mpg and 63 best Swindon to Norfolk. Usually 58-60 on a run within the speed limits.
169 1.2 45 average and about 56-58 on a run driven sensibly within the speed.
Now we seem to have strayed away from the 169's
Do you want to focus on Ecodriving..?
This is getting more tricky..
Comparisons are hard..
Journeys now take more time.. due to housing estates needing traffic lights
Stopping and starting ruin it :(
normal driving at posted speed limits 49mpg
on an economical run (55-60mph on a 100 mile run) 55mpg
2009 1.1 eco active
if you want economy My Royal Enfield 2012 Bullet achieves 95mpg at 60mph
72mpg at 75mph
2011 1.2 Dynamic Euro 5.
Standard alloys with budget tyres, pressures regularly checked.
Air con off, windows up, all unnecessary 'junk' removed to help weight.
90% dual carriageway - max 50mph.
10% city driving - gentle acceleration and try to avoid stopping.
Only myself in car normally.
Regular Tesco unleaded, figures brim to brim from same pump.
Best so far is 57.6mpg (trip showing 61mpg, so showing 5% over)
485 miles from a tank, half way into the red zone.
Only had the car a few months, but have started to become fixated by the mpg readout on the trip computer. Have recently started coasting down every available hill (computer jumps to 141.2 mpg - an unusual figure, not sure why) and now determined to achieve over 60mpg and 500 miles to a tank - just takes so long to empty it !
cuts fuel to the injectors when it recognizes that no power is needed from the engine.
Not sure how fiat implement this but its very smooth.There is a rev limit. As the revs fall you can feel it kick in again so it doesn't stall. I have only felt it a few times in several years of the Panda.
there is a difference between budget and eco tyres, But only below 30 mph. Budget tyres are very noisy.
I find very little difference between windows up or halfway down.
because there's such an increase when coasting. You can accelerate too slowly
gain a couple of mph before a gradient then lt drop a bit on the up slope. You don't have to power all the way to the top. Then pick it back up on the downward side.
I find no difference between cheap and premium fuel
in cold weather the engine warms up quicker with the heaters off Makes a big difference on short journeys
road surface makes a difference. Shiny black ones are good followed by the concrete slabs. Generally the bigger the stones the worse the economy. Sometimes I took a different route because the roads where smoother
my gauge is a little inaccurate after the warning light comes on
weight makes a big difference. Carrying 2 people I get about 6 mpg less on the flat
braking just waste petrol into heat.
I started Being happy with 58 mpg. But as you learn from the onboard computer mid 60s became the norm.
2010 1.3MJ
Tank to tank average:
Best 79.65
Worst 52.85
Currently measuring consumption in weeks to the gallon as I last filled up 10th March! and still have plenty left.
Me too, I filled up on the 21st March and have only done 20 miles since.
Best trip in my 1.4 Tipo was 60
More common mid 50s on a motorway trip driving around 60mph
Avarage for a tank is 40-45
Obviously a Tipo is much much heavier then a panda probably an additional 30-40%
I used half a tank so 20l Or so since 14th march
The fuel supply is cut off when engine is above (about) 1500 revs and throttle is not demanding power. The idle control system kicks in at 1500 revs to prevent it stalling. Put the clutch down while coasting will use more petrol.
My mid 1990s VW Passat Mk3 1.9TDI-90 gave 50+ mpg. I drove it fairly hard and never worried about fuel costs. During the early 2000s truck drivers strike, I had to get to work (Derby to Hertford) so drove VERY carefully proper hyper-mile stuff and walked to work every day. The journey home was just as tedious 55 mph all the way. When I filled up it had done 55mpg.
All that faff for just 10%. I really should have had it chipped as that would have given 110bhp and a similar benefit in fuel consumption. At least it did on the Ford Galaxy which used the same engine.
I have owned a 2006 Panda Dynamic 1.2 since 2009 and know its full history from new. Tyres have always been premium brands - Michelin energy, Continental Eco, Dunlop Street Response and there is no air con so that should give a marginal improvement on mpg
I also have very accurate fuel records since 2009 based on full tank to full tank. Refuelling is at whatever supermarket is cheapest on the day
The Panda is our second car, and get very limited running - total milage from new is under 44,000. We are out in the country, so no local shops or paper delivery. The typical use most days is a 10 mile round trip to the nearest supermarket and once a week Mrs FarNorthPanda does a 25 mile round trip - this is all on local roads. Long journeys on motorways etc are a rarity. All of that will tend to worsen the mpg
Fuel consumption works out at 42.2 mpg average for the last 11 years. Best performance (tank full to tank full) was 54.3 mpg and worst performance (tank full to tank full) was 34.7 mpg
I have owned a 2006 Panda Dynamic 1.2 since 2009 ...
I'm surprised it is lower than my 49 with aircon. I guess you are doing more commuting type driving, or have more hills, etc. Fairly flat around here, and try to avoid shorter journeys in it. For most of my time with mine, short journeys have been relegated to the 'company car', which is of course more able to deal with such journeys.:D
