tobyd10
- Dec 27, 2008
- 95
- 35
Will try the o ring 14463980 on the ignition coil.
None on eBay in the UK!!!
Anyone know where to get one without paying a large delivery charge?
Cheers everyone.
Will change the rocket gasket as that's rubbish and reuse the o ring with some hylomor.
See what happens.
Recently changed the engine and gearbox oils.
A phone call to Shop 4 Parts should get it delivered for the cost of a first class stamp.
But I think your problem is the clutch end crank shaft seal. The only fix for that is separating the gearbox and removing the flywheel. If it gets any worse the clutch will start to slip solving any worries about what needs to be done.
Where did you get the O ring from ? Any reference numbers etc other than Mentioned above ?
I am in France and its impossible to find one here .
