- Sep 14, 2009
- 19,492
- 3,294
Ive had a couple of occasions where the driver's side back brake has grabbed enough to squeal the tyre. Pretty scary TBH especially as there was no ABS action.. I've rechecked by braking hard (in a straight line) to trigger the ABS. The ABS does work as it should. There are no warning lights.
There is no binding on the brake so can anyone suggest the cause? I don't want to do a strip-down only to find its the same afterwards and it really needs an exchange caliper.
Has anyone else had this issue? Grabby rear brake that does not bind.
