Hi all, long time lurker, but now have some issues!
My wife is the lucky owner of the first Panda Cross 4x4 model into the UK in 2008 which was used by the Press in their evaluations of the model! When I have 5 posts I will put up some pictures!!
The car has run well since we have had it (5 years). However it has not been used much recently and has been tucked up in the garage!
The car was due for it's MOT last Friday and on the way to the garage the clutch malfunctioned! By malfunction I mean the car was in first gear and on releasing the clutch pedal nothing happened - the clutch pedal came all the way up and nothing happened! I put the car into neutral switched off the engine and the car was pushed to the side of the road out of the traffic queue!
I then restarted the car and into first gear and pulled away as it nothing had happened and drove to the garage successfully.
As I arrived at the garage forecourt I stopped the car and decided to move forward a couple of feet! Then same thing happened! Into gear (no graunches or other supect sounds) and on releasing the clutch it came all the way up but no traction!
The receptionist said that they could not carry out an MOT if the car was undriveable, so I had to leave the car for their Master Technician to locate the fault with the clutch.
The following day I heard from the garage that the car had passed it's MOT but they had not been able to find a fault with the clutch. Apparently it had righted itself whilst in their care! So I will try to collect the car from them this morning!! Watch this space.
The car has only 32,500 miles on the clock and sits in the garage mostly these days, so it may be that lack of use is the issue!
If anybody has any clues to the problem I would appreciate it.
