- Feb 7, 2017
- 5
- 1
Just noticed the right indicator light on the instrument cluster is off on my 2010 100HP. Actual indicators all working fine.
Had a good search here and not found much about replacing these bulbs. Not a common problem then? Could it be some other electrical issue?
Found pages on here : /panda/345152-remove-instrument-panel-how-hidden-roll-cage.html
And this on the punto: /punto-mk2-2b-guides/228925-changing-instrument-cluster-low-spec-punto.html
(says I'm not allowed to post full links)
From those pages it seems like removing the cluster is straight forward, does anyone know if the bulbs are easy to get to from there?
