peterbryenton
When indicating a left turn and braking, the rear light cluster bulbs "interact" and the audible ticking warning gets much faster than normal. The lights work correctly when illuminated in isolation.
I suspected an earth fault or dirty/corroded/wet contacts inside the bulb "pod" but everything inside that unit is clean and dry, including the multi-connector's pins and socket. No sign of any chafing on the insulation.
I can't see any local earth/chassis/ground connection near the wiring loom under the boot liner and other "felt" material on the LHS.
Any suggestions as to where to look next please?
Peter
Peter
