- Jul 1, 2012
- 425
- 226
Back in August, I did a 5k mile round trip to Morocco in the Panda, and all went well.
I'm thinking about doing it again this year.
But.....one thing I noticed last time, was that the engine temperature got pretty high at times.
On the motorway at 70mph in 45 degree heat, it would sit around 105-106 degrees, which is fine, gauge was just a smidge over half.....but as soon as any incline came along, it would rise to 110-112 which is when the temperature gauge would go up to around 3/4.
Around 3 months before the trip, it had a new water pump, new radiator, new hoses, new thermostat and 50/50 coolant mix.....so the system itself should be fine.
So, has anyone got any suggestions on how to keep the temperature down?
Its the 1.3MJ engine.
I was thinking of running a pure water mix with an additive (Purple Ice/Water Wetter)? Supposedly transfers heat better?? Temperature never drops below 20, so no need for the antifreeze part.
Make some sort of heatshield between the manifold/cat/turbo and radiator? Reduce the heat from the exhaust affecting the rad so much?
