Technical No 12Volts power to fuel pump
Mypanda
There is no 12V coming to the fuel pump. I have checked fuses and the fuel pump relay . There is no 12 Volt supply coming to activate the relay .
Any ideas?
I have jumped the relay and put 12Volts directly to the two main terminals on the Bosch VDO pump. It still doesnt work. There are 2 other terminals on the pump. I dont know what these are used for. I presume they require a voltage or earth.
As I said earlier, I couldnt measure any voltage on the supply side to the fuel relay with ignition turned on.
Any ideas?
