Mine been like this too.... also got a heating issue.... would they be connected?
Chris
So how long should I give it before I can safely assume that it was just the battery?
Not that long Ha Ha
Glad it’s all sorted
Light came on today and stayed on, but steering feels fine. Any ideas?
I’ve not triedWhat happens if you select city mode?
I’ve not tried
100HP has the steering in high power mode by default. Sports mode peps up the engine (slightly) and turns down the steering power.
Connect a voltmeter, you can see while driving, to an ignition controlled circuit. It's possible the system volts are dropping causing the steering to trip out.
But it seems odd as you have new battery and alternator
It isn't always the battery or alternator that's responsible; there are other reasons why the light may be on. If the light is on but the steering still works normally, it's less likely to be a battery issue.
I'd like to put this car onto proper diagnostics and see what faults are stored. It needs to be MES or Examiner; a generic code reader isn't sufficient.
I'd also like to run a steering recalibration from MES.
I've a theory about this, but I need more information. I've had similar, equally hard to explain issues with the Power Steering on the 1.2 Panda that are definitely not battery or earth related.
Next time you're driving at parking speed, put it into city mode and see if the steering lightens.
No light on way home
