Old 02-12-2019   #1
Coolant
On my fiat-panda-eleganza where the coolant bleed screw is near the bulkhead can you take this bleed screw out and replace it with normal stright through pipe etc
funkie75 is offline Reply With Quote Quote
Old 03-12-2019   #2
Re: Coolant
why ?
koalar is offline Reply With Quote Quote
Old 03-12-2019   #3
Re: Coolant
You could - it's an M6 thread but why would you want to? If it's needing regular bleeding you need to check for head gasket failure.
DaveMcT is offline Reply With Quote Quote
Old 03-12-2019   #4
chris3234 has donated!
Re: Coolant
Why would you want to?
Once bled you shouldn't need to touch the screw again until the coolant is changed again
chris3234 is offline Reply With Quote Quote
Old 10-12-2019   #5
Greece
Re: Coolant
Quote Originally Posted by funkie75 View Post
avoid doing this, because the coolant bleed screw is important when servicing the coolant system to bleed the air from the coolant system
if air remains in the coolant system, then coming unexpected overheating issues and no heating air in the cabin
antonis132 is offline Reply With Quote Quote
Old 10-12-2019   #6
Re: Coolant
I can see the value of using a syringe to suck air out of the heater hose loop. But if you squeeze the radiator top hose, fluid will bubble through the heater hose bleed hole. Put your finger over the hole while you release the hose. Then repeat. Put the screw back in when coolant is running out.
(T) what Coolant & Coolant Capcity dan200484 Punto (Mk2/2b) 15 20-10-2019 13:39
(T) Coolant leak 2001 Sei - 3 bottles of coolant in 1 week! dukeluke Cinquecento / Seicento 12 30-11-2016 11:19
(T) Coolant leak/oil in coolant Samuelb86 Stilo 7 02-06-2015 19:07
(G) Engine coolant (water or coolant fluid?) damaguz Scudo 3 13-05-2014 16:52
(T) Which Coolant? Advanced Driver Cinquecento / Seicento 4 11-08-2007 21:29
