I cleaned out the throttle body until it was crisp white. Is there another valve I should be looking for
Sorry missed that. No airleaks anywhere?
gr J
Impossible to say. Run some tests and see what you find. Error codes might help but it could be within normal range resulting in no errors.
gr J
So quick update...
I'm going to twin charge the little 1.4 turbo from the Mito. Why you might ask? Just watch turbos and temples 2 of mighty car mods and listen how awesome the little nissan march super turbo sounds and getting a nice low end gain but its more geared towards the sound. Supercharger will be either of a 4agze sc12 or sc14 or from the golf 7.
Oil filter and cooler will be relocated, ill be using the stock panda black water pipe and relocating turbo water return and also relocating turbo drain.
Massive fabrication but I'm so keen to get started!!!
Also want to add the 4wd drivetrain but I doubt it will be able to withstand the power
