Thread Tools
Old 21-10-2019   #1
Old Gitt..
goggs has donated!
Paracetic Battery Drain.
Hi there guys & gals. My cars this 2011 Multijet and seems to be loosing half a volt (-1/2volt) over night. So I'm looking for easy way out as I'm old (68) and decrepit and sook oxygen throu a straw. So where's the likely answer, radio, amp system, switch, etc, as has been found by past magicians.
Thanks..
goggs is offline Reply With Quote Quote
Old 21-10-2019   #2
varesecrazy has donated!
Re: Paracetic Battery Drain.
Hi.
Radio..
Do read the punto mk2 GUIDE for a praletic drain though..
Old 22-10-2019   #3
some numbers would be useful. You might not even have a problem as the battery does settle
you also need to measure the drain to be sure it not just an old battery thats not holding its charge.
a working Panda with the doors locked is 800 ma and drops down to 39 ma after around 30 seconds
After a run the battery will measure around 14 volts and drop down to around 12.5 volts over night. A bit less if the battery is old
if the radio is faulty you would hear the radio on as you enter the car.
the normal work around is to leave a CD in it
koalar is offline Reply With Quote Quote
Old 22-10-2019   #4
Paracetic can be can when you've been Paraletic the night before.
Radio is the favourite, but old batteries can lose power very quickly. I had one that was fine at home but went flat when parked on a hill. Debris in the cells was shorting out when hill parked.
DaveMcT is offline Reply With Quote Quote
Old 22-10-2019   #5
Old Gitt..
goggs has donated!
Yeh its a new Bosch battery its been trying to flatten for a while now. Had an idea you guys would come up with the radio sooking volts. Is it same with Panda where the power doesn't just go into Radio head when cars sleeping but power feeds amplifiers and all speaker systems as well.
Old 23-10-2019   #6
the problem with the radio is normally the CD micro switch
if the radio isn't on in the morning its unlikely to be the problem.
there's only a problem if the CD slot is empty.
The normal way to diagnose a drain is to measure it. Then remove fuses until the drain is gone
there's always a small drain to keep the clock running and remote receiver alive
Thread Tools
(T) battery drain edwin884 Punto (Mk2/2b) 2 13-12-2012 11:55
(T) Battery Drain bgdobbie Stilo 1 05-02-2012 17:59
(T) Battery Drain Hellcat Tipo (Classic) 8 07-10-2009 14:26
(T) Battery drain barneyb Punto (Mk2/2b) 6 22-08-2005 19:09
(G) Help - battery drain vix92008 Ulysse 5 07-02-2005 08:20
