Hi Guys
First up, hello from Sunny South Africa.
Just got a Panda 100hp and am thoroughly enjoying it! It is a 2008 model and has a 170 000km on the clock. (That’s like 250 miles for all the imperialists out there ? jk)
The little bamboo brat seems to have a bit of a hiccup and hopefully you guys might have a solution. Just FYI I am a qualified mech and have been in the Italian game since 98 with Fiats and Alfas.
The problems:
Ambient (Outside Air) Temp Sensor does not seem to be working with ---C displaying on the dash. At times it reads -8C with possible ice on road warning (it's summer) only chance of ice on road is if grandpa spilled his Brandy in the driveway again.
Struggles to start on cold mornings. Cranks-Starts-Dies immediately. Applying some throttle when cranking ensures that it doesn't die once started.
Coming to a halt at a traffic light for instance as soon as the clutch is depressed the RPM hunts between 700 - 1200rpm 3 or four times and then stabilizes.
That's it, otherwise the car is pretty awesome. Previous owner fitted a BMC cone filter, the filter is installed right after the MAF and the car is fitted with an exhaust system front to be back.
Before I go and mess with the plumbing and ripping it all apart. What do you guys recommend looking at?
Regards
Chris
The problems:
Regards
Chris
